cdcorpe's avatar
cdcorpe
parasitic drain
My rv has a 12 volt valve for the propane tank with to much parasitic drain, is there a way to leave the valve in the open position without the battery drain? ( it has a manual shut off) I tried a large magnet, didn't seem to work. the only way to open the valve is with the switch on , using 12 volts.
Having RV issues? Connect with others who have been in your shoes.24,401 PostsLatest Activity: Aug 06, 2017
