JimH190's avatar
JimH190
Parasitic voltage due on Roadtrek 190
My 2010 Roadtrek 190 batteries both coach and chassis both go dead in a week to 10 days. I have replaced all the batteries and make sure when I park the unit that the invertor and chassis battery switch are both off. Is this a common fault with the Roadtrek 190?
Our dealer support in my area is very poor and when I called Roadtrek directly asking for information about the system so I could maybe find the problem all I got was the answer that I must have modified the system as this never happens to their units. Does anyone have any ideas so how I can locate and solve the problem. problem
  • The 2008 Chevy chassis has a history of starter battery discharge, but better on later and earlier years. Even so, it shouldn't kill the house batteries at the same time. You might want to see if the separator has failed and is locked in all the time. It would pull about 1.5 amps and from both batteries, so it could do the deed in 7 to 10 days.
  • Often times things like the propane detector are not turned off by a master disconnect.
  • I dont have an RT, but a conversion RVan. I have had persistent leakage ever since I had an alarm system installed. Various mechanics have found/fixed problems, grounds and bad wires (my van is old) but I finally had a "priority start" installed and carry a "jump start" just to be sure.
    Are there fuses for different parts/items/areas in the RT? Pulling a fuse and checking the battery charge after a day might at least narrow down the culprit. Most times a nail or a screw nicks a wire and that is where the leak is occurring. It is just really bad luck.
