Gjac
Jun 28, 2017Explorer III
Cobra21 wrote:. My switches turn out to be good. After fighting with it for another day and some reasearch I ended up pulling the two wire harness of of the solenoid inside the steering coulum and that has allowed me to shift out of park.Gjac wrote:Cobra21 wrote:. Thanks, what I have is two switches side by side, one has a 4 wire harness going to it, based on your post I am thinking that is the brake light switch, the other has two 2 wire harnesses going to it, I am thinking this is what you are describing as the park release switch. At any rate I spayed silicone spray on each one because they seemed to be hanging up a little. My foot brake switch would not go on all the time also so I sprayed that one also and it is smoother and came on every time I depressed the foot brake a 1/2 in down. I am hoping this works for the park release switch also. Will check tommorow when I move.
Yes a P30. It has been 5 years since I did this. I can check tomorrow but one of the switches is most likely the brake lights, and the other for the park release. You only have to push down on the brake pedal normally for this to release from park. Pull the wires off the one that does not look like the brake light switch and try that. Make sure the brake lights still work after doing so.
I think you have it now. My switch was sticky and I opted to not.
have it once I discovered by taking a wire off it would never work
and I didn't have to have this safety feature that could cause further
problems. Also I'm the only driver and always put my foot on the brake when changing gears.
Hope you have fair travels, Brian
