Sam_Spade
Oct 12, 2016Explorer
kmb1966 wrote:
Am I ruining my tires parking it on the limestone gravel? Is it a moisture problem that we are trying to avoid with the plywood?
NO. Given the movement you described it should be fine.
It is mostly constant moisture along with acid "dirt" and flat spots that are problems. You should have neither.
38,766 PostsLatest Activity: Jan 10, 2026
