rgatijnet1
Apr 29, 2013Explorer III
I am assuming that you have an asphalt driveway. Just dig out the asphalt areas, where there are craters, and pour a 24" x 24" by 24" deep concrete spot in the asphalt. This will handle the weight of the coach the next time. Add two layers of 4-#5 rebar at 90 degree angles to each other for additional strength. This will use a little less than 1 yard of concrete so the cost should not be that bad.
38,705 PostsLatest Activity: Jan 27, 2025
