I can't for the life of me find a part I need because I don't know the proper name. In the black/grey tank drain/flush basement compartment there is a hole, floor drain, access hole.... that has a pl...
On some coaches the hole is too small and you have trouble putting hose fittings thru so I bought the next size bigger in diameter and cut hole a little larger to mount! and no problem !
