45Ricochet
Nov 06, 2015Explorer
Good for you.
They might all have different levels of PSI for the brakes but I read on the Tiffin forum, or the Freightliner manual that they will lock at 45PSI. The dash low air will will sound the alarm at 85 PSI, IIRC. Should give you time to pull over unless the tank would blow like a tire does.
Did you use the lanyard every so often?
38,782 PostsLatest Activity: Aug 31, 2026
