There is only one charge wizard.. What you meant to ask is what size coverter do I need and the answer is non-sufficent information
You said Two Choach Batteries
Two Group 24 is 150 amp horus times 0.30 = 45 amp converter
Two Group 29 is around 200 amp hours times 0.30 = 60 amp converter
Two GC-2 Golf car batteries = 230 amp hours times 0.30=690 so round to 70 see note
Two 8D = about 500 amp hour times 0.30 = 150 amps.
See how it works.
NOTE: My coach came with a pair of GC2 plus the starting battery and they gave me an 80 amp.> The result was the first few years I only had to add distilled water to the GC-2 about annually and they just missed 9 years by about a month, the starting battery by about 3 months.
In short.. A very good match.
The 0.30 comes from Xantrex, and is specific to most wet cells, GEL types use 0.20 and do not use a charge wizard controller as they will damage GEL's (Of course big 12 volt GEL's are very rare) AGM's. depending on the brand, the 0.30 can be as much as 3.00 and the wizard is good there, will do no harm.
This is why I say GEL is a very bad choice.. But I do not feel AGM's are worth the added cost so I do not recommend them either.
