mc_line's avatar
mc_line
peaked aluminum roof sealer
Any recommended peaked aluminum roof sealer?
Will this product do the job?
https://www.amazon.com/Dicor-RPMRC1-Elastomeric-Metal-Coating/dp/B003YJJX9I/ref=cm_cd_al_qh_dp_i
This is for a 2005 holiday rambler admiral
  • You have leaks in an aluminum roof? Do you know what is leaking or where? It's certainly not the ntire roof so figuring out what you are trying to seal is very important.
  • That product will work just fine. If there are cracks in the factory applied sealer tape, you may want to remove it, clean the area, and apply a new strip of EternaBond tape. The sealer that you found is fine for any of the other roof penetrations.
  • What are you needing to seal? Is there something wrong with your roof? If vents and other openings it seems the most widely suggested item is eternal bond tape and Dicor self leveling sealant.
