Cider
Jun 16, 2020Explorer
Tiffin only has the Open Road, just different lengths and layouts. Fleetwood does not even come close to Tififn and Newmar. I think you need to figure out how much you want to spend, whether new or used, then go from there. If looking to buy a quality product new, nd your budget doesn't match - then look at the newest, used coach you can find for the maker you are after. Also - realize the the frame is all F53 ford chassis, with the V10. Based on age, some will be 5 speed and newer ones will be 6 speeds. Also, various frame weights (22K, 24K and 26K #'s) exist and smaller frames have 18" tires rather than 22.5" tires. as smaller tires do ride a bit rougher.
