Executive45
Jun 02, 2015Explorer III
Just make sure you use the proper receptacle. The one you want is a Nema 14-50. That will be embossed on the receptacle...RVs use 14-50 P for plug and R for receptacle.
For those interested, here is what I use before plugging my coach into any outlet, be it my own or a campground's. It can be found on the link provided above...Dennis
Mine is several years old so the SKU's may have changed.
50 AMP Tester
Parts: Parts are from Home Depot
1. ¾” 2 Gang 59cu Grey Plastic Electrical Box SKU 534-714 One
2. ¾” Female Adapter SKU 202-924 One
3. FS Box Cover Double Duplex SKU 872-585 One
4. 20 AMP Nylon Duplex Receptacle SKU 250-376 Two
5. 12-4 SOOW 600V Rubber Cord SKU 369-269 1 Foot
6. ¾” Strain Relief (2 pack) SKU 115-416 One
7. Angle Plug 2P 50Amp 14-50P SKU 614-001 One
8. 3 Wire Circuit Analyzer SKU 345-238 Two
9. Hi Vis Tester GET-213HV SKU 327-838 One
Total Cost: About 53 Bucks
In addition, you will need a plug in Voltage Meter from Camping World or similar. About 16 bucks w/ Presidents Club discount. You will also need a small, about 1” piece of scrap ¾” conduit. (to join the female adapter to the 2 gang box.
Tools you will need:
1. Phillips Screwdriver
2. Wire Strippers
3. Wire nuts
4. Dremel Tool or similar
5. Common (slotted) Screwdriver
6. Soldering gun, solder and flux
7. Household Plastic Glue
8. Grey Caulking Compound
50 AMP Tester
2. Wire Strippers
3. Wire nuts
