Ivylog
Jun 02, 2015Explorer III
ScottG wrote:
I strongly suggest you set yourself up with a 50A receptacle that has a breaker next to it. That way you can turn off power......
The OP's HR has a time delay of aprox 20 seconds before the power is applied so no load when plugging in. Other than turning the ACs off before disconnecting I would not worry about hurting the contacts.
I wonder how many times in a CG people plug in/out without turning the breakers off? As the owner of a CG I have never replaced a 50A outlet in 20 years, the 30 amps ones YES.
I do have a couple sites with just a 50A outlet, but I did put in a separate grounding rod for it.
