- Bruce_BrownModerator
- AirdaileExplorer
janegowest wrote:
Thank you! It looks great, but I can't see the color diff, since the "after" was shot much farther away. :)
A little closer of the after.
janegowest wrote:
Bruce Brown wrote:
Agreed. Depending on how bad it is you may be able to wet sand out the bad spots and reclear. Be careful not to get down to primer or you'll need to fix the paint as well. Thats not a terrible job either but easier if you can avoid it.
Thank you!! The clear coat is peeled and the paint underneath is faded. What kind of paint did you use? And what clear coat?
You'd want to ask your local automotive paint store what would be best for a spot repair. The technology in these coatings changes regularly. A lot of the new stuff is water based, I haven't used a water based clear yet. For my clear work I have some of the old school stuff left from previous jobs. Most of my painting lately has been on my old farm tractors, I use a single stage urethane for those. - Dale_TravelingExplorer IIConsidering the topic is problem with a peeling clear coat owners experiencing problems should avoid using Zep or at least consider it a nuclear option (once used very difficult to unuse). For dull and chalky gelcoat fiberglass it does work well and will stay on the coat for at least a year before needing attention. Painted rigs, which is what clear coat is, the result have been mixed and biased towards not good. There have been problems with the coating starting to peel off after a few months. I use Zep on my gelcoat rig and it has worked well for me.
If you dealing with paint and clear coats problems work it the same as you would you daily driver. Wet sanding to feather the edges and applying the clear or head south of the board and redo the entire coach. Navarros Body Shop
My 11 year (at the time) Zep coach -
Your results WILL vary. - Jayco-noslideExplorerIn answer to a previous post, we did not have clear coat but just dull and faded finish. I put on 3 or 4 coats of the Zep initially and the shine lasted months but I recoated on this winter trip.
Note: have not proof that it couldn't harm a finish but hasn't mine. - THutchExplorerIf it is a Winnebago product, you can go to the paint facility in Forest City Iowa. They did our 2005 Itasca Meridian a few years ago...roof edges, front cap, & some other areas. Color matched, and quick one day turnaround for under $1k. Was very happy, and well worth the trip up from Florida.
- jsr21ExplorerJane..maybe could ask Mookiekat..she may know
- janegowestExplorer
mike brez wrote:
How about a trip to Mexico
Oh?? Please tell me more! - mike_brezExplorerHow about a trip to Mexico
jplante4 wrote:
I repaired this area on the Sahara this summer.
I used a plastic scraper to remove any loose clear coat, then a Magic Eraser to clean the paint. Lightly wet sanded the edges of the clear coat then shot it with 2 light coats of Nyallic.
No, the color of the unprotected area doesn't match the color that was covered by the original clear coat, but at least the deterioration has been halted.
But, WOW!!!!! I looked at some youtube videos of this product demo and they looked incredible!!
38,782 PostsLatest Activity: Sep 10, 2026
