- bullydogs1Explorer IIYou should also check the CCC rating..mine does not have a tag axle and by the time Navistar took over, this SKQ started having a tag due to low CCC....My coach is just under so I am fine, but depending on what you are carrying in it, you are going to be close to max..My CCC is just under 2000 lbs...
- bullydogs1Explorer III have a 2009 Endeavor...this is a case where there is good/bad in any lot...do you have a service history...Batteries/tires/filters etc.
Regardless of mileage if they are original you are coming up on end of life for batteries and depending on tires as well....As for the coach itself, this was the last year of the old Monaco before things started going sour and the recession hit. I love my coach...I know how everything ticks and once I took care of initial things, it is just a gem.... - The_TexanExplorerGo to the Monacoers forum and pose this question. There are 3400+ registered Monaco coach owners there and many will have the same coach. You will get much BETTER responses from those that own that particular year and model than you will from the one or two that are on this forum.
38,783 PostsLatest Activity: Sep 24, 2026
