Artum Snowbird wrote:
It's a possibility for sure. You can try it again, and then try pumping up your own system and then leave the taps tight and start the hot water tank to see what happens.
I always run the Hot Water heater and I'm running it now without an issue. The hot water heater is in a separate location from the city water inlet and that hot water heater area was dry.
ronfisherman wrote:
High water pressure can cause a leak. Are you using a water pressure regulator?
No, I wasn't using a water pressure regulator, because something is wrong with mine. It completely restricts flow. We were in Fort Wilderness and I've never used a pressure regulator there before. We are going again next month and I'll pick up a new regulator and see what happens when I am there.
However, if high pressure caused the leak, wouldn't it still be leaking now?
Thanks for the responses guys, I appreciate it!
-Michael
