Bordercollie
Sep 13, 2016Explorer
Check the date codes on the tires. Tires that are older than 5-6 years old may be unsafe especially if they have been sitting parked for long periods and have any cracking of sidewalls. Check the entire brake system including operation of calipers, replace front flex lines and flush fluid if not done in last two years. Check engine cooling system including clutch fan and all belts and hoses.
Fridges, roof AC units, converter charger and house batteries and fresh water pump may need replacement in near future, ours died at around 10 years old.
Run the RV generator for an hour about once per month to keep it in good running condition. Let generator warm up for 10 minutes then turn on roof AC unit for load and to keep AC in good condition. Drive your rig at least once per month for an hour or so to and use the dash AC unit to keep working properly. Learn how to check and maintain the house batteries and monitor charging system.
