2_many_2
Sep 16, 2016Explorer III
Tom_M wrote:jtrux wrote:The controls for the AC and heater are vacuum operated. You may have a vacuum leak. If that's the case, that also may be causing the engine misfire.
The only issue that popped it's head up on the way home was that the dash AC would come in and out. It would be blowing ice cold for a few minutes and then everything just stopped. Few seconds later, it would do it again.
Any ideas?
X2, With a vacuum leak the climate controls will revert to default mode (defrost). This has the cold A/C air blowing on the hot windshield.
