- stan909ExplorerNice rig. I put Hurcules Terra Trac AT 2's on my Class b. They are a very aggressive tread and very stiff sidewalls. They handle 2980 lbs each and were $580 mounted balanced out the door. Also have road hazard. Really firmed up the ride with little noticeable road noise.
- Traveler7ExplorerThanks Ol'Grouch!!
I have some scale weights on it and they are right around 6100 like yours- empty tanks as well. I will pull the hub cap today and check it out! I am looking at Copper Tire Discoverer AT's for price value and generally good reviews, what tires are you running?
Here are some interior pics: - ol__grouchExplorer10K pounds GVW? What axle are you running under the rear. If you look to gross out at 10,000 pounds, you definitely need at least 8 ply tires. Pop your rear hub cap off and look at your axle. If it's a full floating axle, yes, you can go 10,000 pounds. That will have a portion of the axle sticking through the wheel. The axle doesn't carry the weight on those but the heavy wheel bearing does. If the axle is flush with the wheel, you have a semi-floating axle. On these the axle carries the full weight in the rear.
My Class B weighs in at 6100 pounds with a full fuel tank but otherwise empty tanks and a semifloating axle. A 4 or 6 ply truck tire will work on these. I've had numerous Dodges through the years and they are really tough trucks. I've also seen semifloating axles snap from being over loaded. - gboppExplorerCongrats! Nice rig. Enjoy your travels.
How about some interior pics? :) - midnightsadieExplorer IIget the best michlin M S 2 in either 8 or 10ply will do you a great job.
- hl_remingtonExplorerDon't know about tires but, that is one good looking van.Thanks for posting
38,743 PostsLatest Activity: Aug 09, 2025
