spotrot
Oct 16, 2013Explorer
Pics: Slide mechansim, Winnie/ Power gear / Kwickee
In case some members would like to see the guts of the FLS DigiSync slide used on many Winnie and Itasca models:
The motor (electric, 12V) is bolted to the small gear box and is sold only as an assembly for about $275.
The gear box is bolted to the outer slide tube which is bolted to the RV frame and thereby is stationary.
The short gear box shaft slides into to the long acme gear shaft and is pinned to it so that the shaft spins when the motor is turning. The far end of the acme screw shaft is held by the rectangular black plastic piece that slides into the inner slide tube.
A plastic 'nut' ($6 - but shown broken here) is threaded onto the acme screw shaft and attached the inner slide tube by two dowel pins. When the motor and acme shaft turn, it forces the nut and therefore the inner tube to move in or out within the outer tube. The slide is bolted to the inner tube, so it moves in or out when the motor turns.
