6ofus's avatar
6ofus
Pipes Burst
Just curious...other than damaging the hot water heater, what kind of damage happens to the RV when the pipes freeze up and burst?
Thank you!
  • winterize the rv, its a pain to fix broken lines and some times big bucks to repair the damage.
  • I had the inline plastic water filter burst and under normal city water pressure it was fine but higher pressure it would leak. When not hooked up to city water, the water pump didn't pump as well due to air in the line. It took me awhile to track down the leak.
    To prevent future problems, I open two drain lines under the trailer and drain the water lines and water heater when freezing temps are predicted.
  • wa8yxm's avatar
    wa8yxm
    Explorer III
    The pipes in most RVs are made of PEX.. They don't burst when freeze/thaw happens.
    Oh the water heater will
    And the assorted elbows. t's adapters. valves and other fittings may well crack or burst
    But the pipes. never.
  • 1. Water Filter housing broken if you have one
    2. Water Pump head
    3. Icemaker/water valves on residential refers
    4. Icemaker feed line and valve on RV refer Icemakers
    5. Clothes Washer hot and cold valves
    6. various elbows and t connections on the water lines
    7. Toilet Water valve
    8. ANY lines that expand too much and crack, depending on how cold and long
    9. Outside Water Faucet
    10. The Black Tank Flush air gap valve
    11. Some Faucets---the necks that go up and roll over 180 degrees for the spout. The water stays in the spout and freezes Doug
  • Nothing much. Just the damage you must cause accessing the broken pipes to fix. And the damage cause in the spring by the water if you don't know the pips are broken.
  • Unless the coach is left unattended for a period of time in below zero temps, it is doubtful that the WH will freeze. Usually it is water in the lines that feed the hot and cold water systems that freezes. If the coach is being used, like our is sometimes in zero temps, I only needed a 100 watt light bulb in the wet compartment to prevent any freeze issues. The fresh water tank was kept full and used instead of hooking to park water.
