Son_of_Norway
Mar 17, 2015Explorer
What chassis is your RV, a Chevy? For info try contacting Geoffrey Rosenburg at Alretta Truck Parts #508-788-9409. He is an expert at older RV brake systems. What about the repair is giving you worries? It isn't much different than doing one on a passenger car. Not sure what you mean by the air coil. Your RV might have air bags in the front springs. Look at them and see. If you have them the air lines are sometimes routed into the front access area. You should see an air line with a Schrader valve on either side. Good luck with your repairs.
Miles
Miles
38,777 PostsLatest Activity: Jun 28, 2025
