dakdave
Mar 18, 2015Explorer
What is it leaking?
brake fluid or fluid from power steering unit?
hydro boosts were usually supplied pressure from power steering pump.
if losing brake fluid you need master cylinder.
If need hydro unit they are not hard to change ,unhook hoses remove master cylinder rod that actuates hydro unit.when installing check rod length that enters master cylinder.
To get correct part check casting number,this should help get proper part.
Check with NAPA or brake parts store.
38,777 PostsLatest Activity: Jun 28, 2025
