turbojimmy
Mar 18, 2015Explorer
Travelingfam wrote:
We got the new master cylinder on and the brakes bled and it is working much better now. I found the air valves for the suspension as well. We still have several op stacked to overcome with this thing though. The generator needs a tune up and coil, neither air conditioners work, the turn signals just broke in the steering column, and the muffler is shredded. Not to mention there are no seat belts, they removed the lp, stove and fridge but put in a small electric fridge and much more. We are having buyers remorse.
The MC was bad on my '84 P30 when I got it - I assumed from sitting for so long. It made a HUGE difference when I replaced it. My '84 doesn't have any seat belts either - just in the cab.
No offense, but the stuff you mention is easily visible or easy to check before you buy. Remorse could have been avoided. But it's water under the bridge. Hopefully you can make the best of it with the help in this forum.
38,777 PostsLatest Activity: Jun 28, 2025
