The 50A to 20/15A Adapters are hard to find - may not even exist.. What I would do here if I had a 50AMP Trailer would be to use the standard RV50A to 30A long adapter and then plug-in a RV30A-15A long adapter to be able to plug in the extension cord back to the garage/house 120VAC receptacle..
Just be aware that by plugging into a 20A/15A house receptacle will only have limited current to run your high wattage appliances. You have to watch what is turned on at the same time.
I plug my 30A trailers into the garage 20AMP receptacles all the time here at my house and can run everything inside the trailer including Air Conditioner. I just just can't run two high wattage appliance at the same time otherwise it will trip the house circuit breaker.
I use a HD 10 gauge (10-3) Contractor type 50-foot extension for my 30AMP Trailer. I have used a 12-gauge (12-3) Extension cord but did notice some voltage drop on the trailer side.
I don't think I would even consider using a 14GA or 16GA Extension cord like you see available from WALMART (the red color ones) etc..
I also use a RV 120VAC plug-in AC VOLTMETER inside my 30AMP trailer which has the SAFE ZONE printed on the meter scale that I can check before turning on a high wattage appliance item.
Just feel your connections and make sure they are not getting over heated on you.
Once you have the RV 50A and 30A long Adapters you will find other uses for these in your trailer trips.
Great for visiting the kids and then you can sleep in your RV sitting in their driveway.
Roy Ken
