SuaveGatoExplorerFeb 20, 2016Plumbing wrench? Spanner wrench? HELP?Hello, trying to see if there is a special wrench for the compression fitting on the black plastic plumbing? My shower drain down-pipe has come lose from the "J" pipe and I can't get it tight enough...Show More
liborkoExplorerFeb 20, 2016The white nut is a combination sealing ring and nut in one piece. You can also get a separate sealing ring if that is what you have.P-trap
Related Contenttire wrenchPlumbing Confusiontorque wrenchDog House Spanner KeyPuzzling Plumbing Problem
