CVD
Oct 08, 2017Explorer
PM On 20 Yr Old Coach
Went to Pomona RV show today. Saw lots of interesting coaches (big and small, expensive and less so). We came home, thought for a while, and decided what we have is fine for another year or two. So, I’m wondering what sort of additional preventive maintenance I should consider on my coach of 12 years.
Background
Question
Now that it’s approaching 20 yrs old, anything else I should be doing to prep it for a couple 1,000 mile trips over the next year or two?
Background
- Coach: 1999 Freightliner XC chassis (23,600 GVW), ISB 275 hp engine, MT643 trans; 75k miles (3 – 4 k miles per year). I know mileage is not an issue, but years might be.
Fluids: I change oil/filter and lube all fittings every 24 months. Coolant and trans fluid was changed 6 – 7 years ago (~20k miles ago). Hydraulic fluid has not been changed.
Engine – The only significant problems in 12 yrs have been a bad starter, cracked exhaust manifold, and leaking heater core. I’ve changed the fan belt, have not changed hoses.
It smokes for a second or two upon cold start up. I’ve been told it’d due to leaky injectors, but to wait until it gets worse before doing a $1,500 injector replacement service. Otherwise, it runs fine, still get’s 10 – 11 mpg (not towing).
BTW – this is a “Code 53” engine, no cracks in block, no coolant loss (has been pressure tested to confirm).
Tires – replaced 4 years ago.
Brakes – no maintenance has been performed. (plenty of pad remaining)
Air system – have had cracks in air bags for years, but haven’t changed them or air lines. Air dryer has been serviced twice.
Generator – 6500 Onan LP unit. Runs fine, only 250 hours, is “exercised” regularly.
Question
