Grit_dog
Jan 03, 2022Trailblazer
Use a rotary polisher with the appropriate wool or foam pad and start with a polish first to see if it removes it all. If not step down to a compound first.
Order of application from rough to fine is wet sand (if necessary), compound (heavy cut to light cut, if necessary), polishing compound, then wax. If a dark color, may need a glaze or swirl remover after the polish, but not likely needed or looking for a show finish.
38,780 PostsLatest Activity: Aug 05, 2026
