garyemunson
Jun 15, 2016Explorer II
I found that totally separating double pane windows was not necessary. I'd cut the spacer out of the top and bottom, leaving the sides to maintain the 'structural integrity' of the glass 'sandwich'. I'd pull a small rag back and forth inside the window (with a pull wire) until clean then replace the top and bottom spacer and reseal. Much easier and faster. I used a polishing compound as a cleaner. Double pane are so much better than single. Even more so than in a house..in a house you usually are not sleeping with your head 12" from a window....
38,777 PostsLatest Activity: May 24, 2026
