NeverHome2
Jun 23, 2016Explorer
Polycarbonate originally introduced by GE Polymers under the tradename Lexan can be formulated with UV inhibitors that slow the degradation by sunlight. It increases the cost of polycarbonate sheet products significantly however.
I would think the greatest problem is scratching. Abrasion is the biggest downfall with polycarbonate used in a window application. They do make coatings to try to lengthen the life of the surface but it will eventually wear out and leave scratches.
Stick with the glass and maintain your clear vision.
