Goldencrazy
Mar 20, 2015Explorer
I didn't think it was a good idea even porcelain that has a bit more flex but was aware that Dolphins had it in some models years ago so wanted to check. We are getting used to what we have so may be awhile until we replace it.
MagillaGorilla wrote:
Beyond the weight issue is the issue of flex. Ceramic tile does not allow for any flex or any imperfections in the floor. The tiles will crack and lift. For a motorhome you need a flooring that has some flexing abilities. If you do decide to go with ceramic tile, be sure to pick out what you will be replacing it with while your at the store. It will save you a little time down the road. ;)
