Deano56
Mar 20, 2015Explorer II
MagillaGorilla wrote:I guess you are unfamiliar with newer motorhomes that are full of ceramic or porcelain tile. I have looked at many used coaches that show no signs of cracking, and looked closely
Beyond the weight issue is the issue of flex. Ceramic tile does not allow for any flex or any imperfections in the floor. The tiles will crack and lift. For a motorhome you need a flooring that has some flexing abilities. If you do decide to go with ceramic tile, be sure to pick out what you will be replacing it with while your at the store. It will save you a little time down the road. ;)
