RoyB
Jan 01, 2015Explorer III
I have been using this Q Industries portable MV50 12VDC 150 PSI TANKLESS Air Compressor available from AMAZON for years. Even back in my JEEP TRAIL days...
The small footprint is what I like with this unit and it comes with a nice carry tote for the compressor and the accessories... It stores under my truck rear seat. Be sure to let this one cool down before grabing it after being used. The compressor head runs very hot.
I have no problem airing up my trailer tires as well as my truck tires. In my case I set the compressor on my truck tailgate which allows me to easily connect my 12VDC cable into the trailer battery bank. Then I can walk around to all the tires using the long coiled hose provides with the compressor kit.
I also use this air compressor along with the CAMCO 36153 Blow Out Adapter to blow out my water lines for winterizing. Being TANKLESS it takes more time to build up air compressor which is ideal for blowing out water lines.
If I went with a 120VAC Compressor I would most likely get one with the included tank.
Roy Ken
Roy Ken
38,769 PostsLatest Activity: Jun 25, 2013
