wsfurrie
Jan 02, 2015Explorer
I have the same unit as RoyB, used it for years on our Pleasureway. The only problem is that for tires over 40 psi one should start the compressor before screwing the filler to the tire valve. If you try to start the compressor after connecting the hose it will blow the inline fuse. I keep 80 psi in the back tires and the compressor will not start against that much pressure. Aside from that it is a great unit.
Wayne
Wayne
38,769 PostsLatest Activity: Jun 25, 2013
