Williebago
Jun 18, 2020Explorer
Possible CCC Upgrade
Wondering what I am missing? It seems like it would be pretty simple and inexpensive. We recently moved up from a 2003 Dolphin on a W22 chassis with 22K GVWR and 26K GCWR to a 2019 Newmar on a F53 chassis with a 24K GVWR and 30K GCWR. Problem is with full water we dropped from 3,300 pounds of CCC to only 1,300 pounds of CCC. So that got me looking at the Ford specs for the F53 chassis and comparing everything between the 24K and the max 26K chassis that both have the same 30K GCWR.
And what I found was that the only apparent difference is the rear axle leaf springs. The 24K has 15,500 pound springs and the 26K has 17,500 pound rear springs. Same front axle and 9,000 pound springs. Same 17,500 pound Dana S17060S rear axle and differential. Same brakes and HydroMax specs and 15" rotors front and back. Same 50,000psi frame steel. Same everything except for rear leaf springs.
If I just change the leaf springs up to the 17,500 pound units I would be back up to the 3,300 pound CCC I have been used to. Since we occasionally travel to football games with "full occupancy" plus cargo we would be at the 3,000+ pound CCC.
So, what am I missing?
