timmac
Jan 21, 2014Explorer
Wrong Lane wrote:
If the tire in your picture has 4000 miles on it there is no way that red stripe down the center should be visible. Even the stripes in between the treads normally disappear within a few weekend trips. That ink, even between the treads, will just wash off on a wet road.
Have you never driven in the rain??
The outer edges look worn while apparently the center of the tire has never touched the road.
Ask your tire shop to look at that tire, something is not right!!
Are you sure you posted the picture you intended to?
That's not my actual tire, its a pic of a new one I found on the web, just showing that the tread pattern is not the issue as to humming noise, the outer tread comes smooth like that.
