timmac
Feb 06, 2014Explorer
Safaribeachouse wrote:
Sounds like you made a good choice, I would love to try those tires, but Hankook doesn't make a tire in my size (265/75R22.5).
I am also thinking of getting Balance Master balancers.
How do you like your centramatic balancers? Why did they use equal if you have the centramatics???
Here is a link to rvnetwork where SKP writes about is observations and tests about of various balancing, including roadforce, on large RV tires with steel rims. It sure puts things into perspective. His is the 6th posting.
http://www.rvnetwork.com/index.php?showtopic=99807
Auto balancers work best if tire is balanced, weights might not be a good idea with centramatices because of difficult in balancing large tires, the tire installer put Equal balance bags in all tires to help the centramatices balance better and I will say it has worked real well, the old tires were not balance and the centramatices had a hard time at keeping the tires smooth running.
