gasguzler wrote:
small generator
This will run all night on a tank of gas and is cheap, quiet. I have one because it is cheaper to run than a 5500 Onan unless I need more power.
Run, don't walk from that thing. That was originally a Yamaha ET800 clone made in the 1970s. It is not designed for anything that is sensitive and if one looks at YouTube videos of the voltage spikes it puts out (no regulation circuits), it should not go near one's RV.
Not to mention it is also loud, fiddly (you have to break it in just right, and that is after you pulled the spark plug and modified the choke to close all the way), and smoky.
I tell people to spend a couple more C-notes and get a Champion generator with voltage regulation. That way, going cheap on the generator won't cost big bucks down the road with other electrical items failing due to surges and spikes.
In any case, the OP has a few solutions for the issue:
1: Expand the battery bank as mentioned above.
2: Add a solar rig.
3: If the OP has a single stage converter, toss it now and get a better one (the five-stage "charge wizard" types are not that expensive and will help batteries, especially with pendant activated desulfating modes.)
4: If expense isn't an issue, consider an EFOY fuel cell that uses methanol cartridges. These are not going to keep your A/C running, but they will run fairly silently and help balance out the charge that the furnace takes up.
5: Use a generator controller either from Magnum Energy or Onan. Those can be set to fire up the generator for a few hours when the batteries end up low. One can also set quiet hours as well.
Of course, there are Mr. Buddy heaters. I have a Big Buddy, but I loaned it to some tent campers (since their tent is so drafty, the oxygen use isn't an issue, and even then, I tossed them a CO detector.) A Buddy heater has to be vented for oxygen and to help get rid of water vapor, has to be placed on a non-flammable surface, and have the propane tank placed outside unless one doesn't mind changing those little bottles every 3-4 hours.
