mike brez wrote:
rgatijnet1 wrote:
If you can rent a 36" power trowel it will certainly make things easier. Placing the concrete should be no problem since the truck should be able to put it right where you need it without a pump or wheelbarrow. Still a lot of work unless you have some help. I would try it with help, even if it were unskilled help. I would pass on doing it alone.
Should have mentioned i will have my two kids they are 20&23 and he dosent know it yet but my brother.
What good are relatives if you can't exploit them. :B
I'd still try to rent a 36" power trowel. This will make it quicker and easier to get a level and even steel trowel finish.
On the big commercial buildings that I used to build, we would use multiple power trowels that you would ride on. Made it easier to finish 50,000 square feet at a time. Have fun.
