Old-Biscuit
Jun 16, 2016Explorer III
Sam Spade wrote:
I would say that one side of your 220 is dead.......but your tests seem to rule that out.
So there is only one logical conclusion left, I think:
Those items that are not working are damaged internally; IE they are fried.
There is no 220.......
There are TWO 120V on RV 50A
Microwave has 120V AC at outlet but no ON/OFF..........internal ceramic fuse blown
Fridge woks on gas but not on AC....check outlet fridge is plugged into for 120V AC. If outlet has power then 5A (possible 8A ---varies with models) glass fuse on fridge control module is blown or electric element is bad
If fridge outlet does not have AC power check for a GFI outlet that is tripped
Converter.....if it is plugged into an 120V AC outlet.....is outlet hot.
IF no--check for tripped GFI outlet
If yes..converter blown
If converter is wired to a 120V AC circuit breaker..then CB tripped
push CB handle to OFF then back on
If CB good....then converter blown
Remember.........120V AC circuit breaker does not always 'look' like it tripped. Turn them OFF then back on to reset.
And test fuses vs look at them
Meter is your friend.....
38,776 PostsLatest Activity: Mar 24, 2025
