Andonso's avatar
Andonso
Power converter putting out too low of voltage
I have a Class-C in a RV Park that pretty much stays in one spot for the last 10 years.
I replaced it's Parallax 35 amp power converter with a Progressive Dynamics 9280 which was sort of an overkill for a 23 foot RV.
I noticed when my Norcold refrig started to produce a Lo_Dc error futher testing showed dc voltage to be approx. 9.5.
Disconnecting the 3 house batteries it appears the 9280 stopped putting out 12 VDC. I'll further test sometime tommorrow but it appears the power converter is gone unless there's an internal fuse somewhere. The three external green 30 amp fuses appear to be ok.
I'm thinking it may be better to look for a new power converter rather than trying to have the 9280 repaired?
I probably don't need 80 amps as I only have 3 batteries which I really don't need as the RV rarely travels anymore and is lived in year around with utilities.
However the RV Norcold Refrigerator which I'm thinking of replacing with an electric does require 12 VDC and then there is the interior 12 volt lighting. I don't use it gas furnace anymore so I don't think 12 volts is really required other than for the refrigerator and lighting.
I've been looking around at new power converters but am not that familiar with their differences and quality.
So far have looked at Progressive Dynamics 45 - 60 amps, WFCO Ultra III 9800 45 amp, (WFCO replacement) WF-9835 - PowerMax 35 AMP, Powermax Pm3-45, Progressive Dynamics PD4560CSV 4500 series 60 amp,
and others.
I'm interested in this one from WFCO to replace my entire AC/DC control panel and board of which the 9280 was installed with very little room underneath. So I'm thinking with perhaps some modifications I can replace my entire existing AC/DC panel and the 9280 with this WFCO.
WFCO 55 amp RV power converter WF-8955PEC
I'm uncertain of the quality of some of the brands such as Powermax, WFCO, etc. when compared to Progressive Dynamics.
Should I stay with Progressive Dynamics?
