dicknellen
Nov 18, 2013Explorer II
Bobbo, your 2007 should have come with 3 Ford keyfobs so I'm sure you can program remotes like Beverley and Ken said. Dick
REMOTE PROGRAMMING
Obtain all remote transmitters.
FIRST THING TO DO!!! Get in your vehicle, make sure all doors are closed and unlocked.
Switch ignition from OFF to ON 8 times within 10 seconds (On the 8th time leave key in the ON position in the ignition):
Doors should lock then unlock.
Within 7.5 seconds:
Press any button on the first remote transmitter.
Within 7.5 seconds:
Press any button on the second remote transmitter.
NOTE: If door locks do not operate: Wait a few seconds and then press the
button again.
If 3 or 4 repeat
Switch ignition OFF:
NOTE: A maximum of 4 remote transmitters can be programmed.
edit 2 keyfobs not 3 Dick
REMOTE PROGRAMMING
Within 7.5 seconds:
Within 7.5 seconds:
button again.
If 3 or 4 repeat
38,769 PostsLatest Activity: Mar 31, 2026
