oregon2
Nov 18, 2013Explorer
oregon2 wrote:Mich F wrote:dicknellen wrote:
Bobbo, your 2007 should have come with 3 Ford keyfobs so I'm sure you can program remotes like Beverley and Ken said. Dick
REMOTE PROGRAMMING
Obtain all remote transmitters.
FIRST THING TO DO!!! Get in your vehicle, make sure all doors are closed and unlocked.
Switch ignition from OFF to ON 8 times within 10 seconds (On the 8th time leave key in the ON position in the ignition):
Doors should lock then unlock.
You can stop right there if your locks don't lock and unlock. You either don't have a receiver (most likely) or it's not wired into the system. I have a MH on a 2013 E450 and I don't have a receiver, so no keyless entry.
So what good are power locks if you don't have remotes to lock and unlock them ? Still lost on this one !
OK- things coming into view now. Guess 1/2 pie is better than no pie at all. Just got of the phone with FORD - they confirmed the FOBS (and I presume a transmitter mounted in the vehicle) are an option on the E-350 Cutaway Chassis.
38,769 PostsLatest Activity: Mar 31, 2026
