KristinU
Nov 19, 2013Explorer
Mich F wrote:dicknellen wrote:
Bobbo, your 2007 should have come with 3 Ford keyfobs so I'm sure you can program remotes like Beverley and Ken said. Dick
REMOTE PROGRAMMING
Obtain all remote transmitters.
FIRST THING TO DO!!! Get in your vehicle, make sure all doors are closed and unlocked.
Switch ignition from OFF to ON 8 times within 10 seconds (On the 8th time leave key in the ON position in the ignition):
Doors should lock then unlock.
You can stop right there if your locks don't lock and unlock. You either don't have a receiver (most likely) or it's not wired into the system. I have a MH on a 2013 E450 and I don't have a receiver, so no keyless entry.
This is as far as we got when the earlier thread came up. Tried it a few times on separate occasions...kinda like staring at the empty shelf at the store hoping the item would magically appear. No luck, so I never ordered fobs or did any digging around to try any further.
38,769 PostsLatest Activity: Mar 31, 2026
