- nemo45Explorer
dbontherun wrote:
Power gear leveling jacks won't retract on my 2014 Fleetwood Storm, any ideas?
Need to know if they are electric or hydraulic and if they are hydraulic is there anything else that doesn't work. Like a hydraulic slide. The power gear website is a good place to go but you need to know exactly what you have. - pweeklyExplorerHad the same thing happen with my HWH and then they wouldn't go down later. Used the manual switch to get them up and then took it to the HWH factory. They couldn't have been nicer and got it fixed up perfectly (under warranty).
- wa8yxmExplorer IIIDepending on the jack, (Hydraulic, Hydraulic, or Electric) there may be a manual override,,, Check the fine manual for yoru jacks.. Mine do not have it However I know an alternate way to do it.
If you have hydraulic and do not have a manual override let me know I can describe two methods. - viajanteExplorer III had the same problem with my rig some time ago. It was the inline fuse. They had only put a 5 amp fuse in and should have had a 10 amp fuse. I'm not sure where yours would be, but mine was on a pedestal behind the front driver's wheel. It looks like a small rectangular box. If you open it, you will find the fuse.
Good luck. Hope that helps. - camper19709ExplorerCheck the Power Gear website. There are directions on what buttons to push to get the jacks up manually. I have done this several times. It will usually reset the computer and the jacks will work properly next time.
