MrDoneIt65
Apr 02, 2015Explorer
The gears are not the problem. When the slide is out you can see the aluminum frame behind the black rubber seal on the edge toward the front of the motorhome. The back end of the slide is almost against the opening. When it goes in it seals properly against the opening buy you can tell it is cocked in the opening. It is a power gear slide mechanism.
This is just another in a long list of adventures I have taken with this unit.
But just in case, I will count the gear mess. Thanks for the response.
38,778 PostsLatest Activity: Jun 06, 2026
