I'm having power issues that I don't understand. This spring the battery for the engine was dead even though the RV was plugged into shore power all winter. It wouldn't keep a charge so I replaced it...
How did you verify power to rig? Are you using an adpater? What size of shore power 30 or 50 ampere? Have you fully reset breakers in the rig? Turn off all breakers applying light pressure toward off. Then turn on main breaker if equipped. Then branch breakers one at a time. Possible that transfer switch has failed. Hit it!
