MountainAir05
Nov 12, 2014Explorer II
The refridgerator and AC both need DC, Battery voltage. If your TV is also 12 volts, then check the couch battery and the battery charger. To check battery, remove the shore power and take the negative cable off the battery and read voltage. Wait 30 to 60 minutes to take reading after shore power is off. If good then check fuses on battery charger and then output. If you need instruction post back.
38,773 PostsLatest Activity: Apr 23, 2026
