MandJ_01's avatar
MandJ_01
Power Steering issues
ok guys heres what I have, replaced master cylinder but did not bench bled,I did bled the brakes also filled power steering turned wheels and added more to level. Now when I turn the wheels in park everything ok but when I put it into drive the wheel stop halfway and than there smoke and the smell of burning rubber from the dog house also the fan slows down and stops as I turn the wheel, It all goes away when I let the wheel go. Does this have anything to with the Hydro boost system?
89 Southwind Ford 460 F53
  • enblethen wrote:
    Verify your routing as suggested if your rig has a serpentine belt.
    Hey Not a serpentine.She has V-belts the routing the same as when it was working.
  • Verify your routing as suggested if your rig has a serpentine belt.
  • Make certain the belt is both tight and routed properly...
    Gary
  • enblethen wrote:
    Sounds like a belt issue. Verify belt alignment and tensioning.
    I did take the belt off and put back on again
  • rgatijnet1 wrote:
    Could you have put in too much power steering fluid which is overflowing and spraying on hot engine parts and the belts when you turn the wheel?
    The level looks good but I will check again.
  • Could you have put in too much power steering fluid which is overflowing and spraying on hot engine parts and the belts when you turn the wheel?
  • Sounds like a belt issue. Verify belt alignment and tensioning.
