sailor_lou
May 19, 2013Explorer
Welcome to the forum. Although I haven't had any issues with mine, I have the same generator. I would start by sliding the generator out and see if you can locate the source. It may be as simple as a loose hose clamp or possibly the plastic expansion tank is cracked. If you are not into repairing it yourself, you do not necessarily need to find a CAT service center. Depending on the problem RV dealers, mobile techs or even a good repair shop may be a good place to start. Try checking here for a local shop with good reviews:
http://rvservicereviews.com/
You may also try contacting your Extended Warranty company for a recommendation, but depending on the problem this may or may not be covered. Good luck.
Lou
05 Travel Supreme Envoy
Lou
