Branman1971 wrote:
CA Traveler wrote:
Branman1971 wrote:
Sorry, it's a 7500 Onan, and I have run both AC s in the past, which is why I'm baffled now. There is one main breaker on the Onan, it's on. Not sure where the others may be.
The gen CB controls both 120V AC circuits. Unless you have something like a whole house inverter then there are likely no more CB's before the main CB panel. We already know that from the ATS on everything is OK since shore power is OK.
So from this I can assume the ATS is ok? I haven't yet checked the input or output legs on the ATS-501. I started the genset again and once it settled into operation I heard the switching (click click click) from the ATS, then I turned on the ACs one at a time and still only the rear AC operated. I will check the output legs tomorrow with multimeter unless there is no need to.
No. Different text would be everything past the ATS is OK instead of "from the ATS on". ie Wiring, main CB panel, etc.
